Changing a SubVI appearance
I would like to run a subVI in the background (hidden) and I did this using SubVi's own File -> Properties, but I would like to add a possibility for users to click on a button to show the dialog what is going on at the other VI.
How can I do this? I could find the option to run another VI in property node.
Thank you for your response,
Message 1 of 8
(4,333 Views)
Hi vgezer,
try the FPWindow.State property...
Message 2 of 8
(4,332 Views)
Thank you for your reply,
but How to indicate which subVI will be considered?
Message 3 of 8
(4,330 Views)
Hi vgezer,
don't you know the name of the VI you want to show?
Message 4 of 8
(4,327 Views)
Oww, OK. Creating a constant for reference pin, it let me choose the VI.
Thank you, problem solved 🙂
Message 5 of 8
(4,325 Views)
Hello again,
Could you post a sample if possible? I think I failed again 🙂
For example:
There are first.vi and second.vi
From second.vi, File -> properties -> Window appearance, I choose Default. This is what I want (it is working in the background).
But I would like to add a checkbox, or a button on first.vi. and when user clicks on it I would like to pop it up as an application window or a dialog.
Thank you very much,
Message 6 of 8
(4,317 Views)
Accepted by topic author vgezer
Check the attached VIs. Open VI 1 and follow the instructions.
Nitz
(Give kudos to Good Answers, Mark it as a Solution if your problem is Solved;))
Message 7 of 8
(4,304 Views)
Thank you 🙂
Message 8 of 8
(4,299 Views)
