Changing a title in vi file
Hi all,
I have a simple question. How do you change the title in the top of the block diagram of sub VI files as shown below? Thanks!
(1,224 Views)
VI Properties -> Window Appearance allows you to change the title of a VI, which is the "same" for both Front Panel and Block Diagram windows.
(1,198 Views)
if you want to change the title while running the VI you can use a property node for the VI Class and write to Front Panel Title.
(1,161 Views)
