Changing an array and keeping the change
Ok i have an array constant formated to a string. The size is 3 col X 13 Row. i am trying to modify certian areas of the of the array and keep it as a new array, then display the changes in a Table. Then once the table is completed i allow the user to print. My problem is that i cant save the changes as a new array and then display it properly. The current version of LabView i am using is 6.1i.
Thanks for any assistance
(2,672 Views)
Try posting your vi.  It would help us out a lot in trying to figure out your problem.
(2,664 Views)
