Changing axis on the fly
I'm looking to change the X/Y axis max ranges at runtime, I know how to do this from within the same VI but I don't see the properties through the Property nodes.
Am I going about this the right way?
Ron
(3,230 Views)
Rhayes wrote: ...  Am I going about this the right way?
You have to use the "To More Specific Class" function to cast the control refnum into a GraphChart refnum to access graph /chart properties.
Message Edited by Donald on 09-05-2006 11:43 AM
Fading out. " ... J. Arthur Rank on gong."
(3,208 Views)
Use the "To more specific class" node (in the application Control subpalette) to change the wire class and tell LabVIEW that you want to access a graph property.
Message Edité par chilly charly le 09-05-2006 05:46 PM
Chilly Charly    (aka CC)
(3,193 Views)
