Changing background pictures of control or Xcontrol
I need to create a control based on a solidworks drawing of a throttle lever. I was able to create 200 individual .jpegs of the throttle lever; one for each position I want it in, but am not sure how to change the picture based on the position of the hidden Labview slide control. I planned to hide a slide control on top of the handle for the throttle lever, and then change which of the two hundred pictures are loaded based on the position of the slide control. I have been trying to figure out how to do it with an Xcontrol, but have never used one before and am sorta stumped? I have not been able to find an example, but seem to remember reading about people doing similar things with the Xcontrol?
(2,803 Views)
For the displaying of the different images you could us my Boolean XControl.
Using a hidden slider will not work.
A better thing would be a picture control and use Mouse Down and Mouse Move events to determine which image to load into the picture control.
Ton
My LabVIEW Ideas
(2,786 Views)
I'm on my way out the door and will check that out in the morning, thanks for the reply. I should probably clarify that I wanted a slide control because I am outputting a throttle position form this control and want to change pictures to make it look like you are moving the throttle lever to choose a throttle percentage.
(2,775 Views)
TCPlomp,  I was unable to run your example. The Demo VI was empty other than an image and there were a bunch of VI's missing that were from your user library?
(2,753 Views)
