Changing cell color in a table based on input
I have been trying and trying with no success. Robot Sad
I do store the values in a 2D array. The problem is that I have to display each value as I get it. I cannot wait to get an entire row/column. Using the active cell property in a property node there is no problem changing the color of each cell as I get the corresponding numeric value (refer to the code provided by Altenbach). The problem is that without the ability to specify an active cell and write a number in it I cannot do the same with the numeric values.
How can it be done?
Message 11 of 16
(2,800 Views)
Why don't you show us a simplified version of your code?
Message 12 of 16
(2,795 Views)
Here is the simplest version of the code.
Thank you in advance for your input.
Message 13 of 16
(2,780 Views)
You need to use "replace array subset", not "insert into array". See attached modification.
(Of course if you only want to fill the 2D array once, even the outer loop should be a FOR loop.)
Message 14 of 16
(2,775 Views)
If you keep the table value in a shift register, you just need to use the Replace Array Subset to update it.
Message 15 of 16
(2,772 Views)
Altenbach,
It is amazing how simple, easy and elegant your solution is.
Thank you very much!!!
Message 16 of 16
(2,749 Views)
