Changing color of text in table
I have LIN traffic table in VI.
I need to change color of line(row) in case that condition is true LIN full frame.
check attachement.
Till now i succeed to change only first element.
Can somebody advise, how to do this??
Thank you.
Milan
Message 1 of 11
(3,325 Views)
You need to set the cell(s) to change using property ActiveCell.
Certified LabVIEW Architect
Message 2 of 11
(3,288 Views)
I set up like in attachment...
But now is everything red, even when condition is not fullfilled.
How to change this...
Best regards.
Message 3 of 11
(3,245 Views)
When I set up row 0 column -2, then this work, but my table doesn't remember color.
As soon the value goes on second row, it becoms red again...
Best regards.
Message 4 of 11
(3,243 Views)
Your False case is setting the active cell to -2, -2 which means the entire table.
Message 5 of 11
(3,234 Views)
Attach a VI t display your problem and we can help. It shouldn't be that hard really to set the colors. I'm guessing you are overwriting the property.
Message 6 of 11
(3,232 Views)
yes overwriting is problem.
Unfortunatelly I am not allowed to place whole VI, and this part of program will not work without rest of the program.
But i placed vi with this property...
Problem: On picture 6 I get first row is green, but when it moves down, it becomes red, picture 7.
Best regards.
Message 7 of 11
(3,193 Views)
In your VI, you are always setting color on row 0.
Try the attached VI. That should help you.
Message 8 of 11
(3,184 Views)
what, where did my VI go, and why does it look like I attached your VIs?
lets try again...
Message 9 of 11
(3,182 Views)
If you add or delete rows to the table you need to re-assign the colors for the cells. Color assignments are locked to the exact cell, not the row/column itself. So if you add a row at the top, all of the color assignments will be off by one.
I have attached some code that I wrote for working with tables that contain colors. I think I grabbed everything. Let me know if I missed any VIs.
Mark Yedinak
LabVIEW Champion
Message 10 of 11
(3,160 Views)
