Changing data in string control
I'm trying to programatically change or delete the data a user has typed into a string control on the front panel of the main vi or reinitialize it to blank default without having to end the vi and run it again.
IE: the user types a lot number into the control, uses controls to run the process, then when the process is complete, I want the Lot number indicator to be blank again so they will have to retype the lot number again before running the process over. LV ver 5.0
(3,617 Views)
The easiest way to do that is to create a local variable for the control and write a blank string to it when you want to initialize it.
(3,616 Views)
you must use local variables.
Right-click on the control on block diagram. Select "Create->local variable" from drop down menu. The local variable associated with control will aappear. You can use it in any place of your VI to read and write data from/to your control. Place it somewhere and wire an empty string to clear control.
The example is attached.
Good luck.
Oleg Chutko.
(3,616 Views)
The easiest way is to create a local variable of the control and wire an empty string constant to it. Where you put this will depend on how your program is designed. If you've got a cleanup state, it would go there.
(3,616 Views)
Thanks, that makes sense. Now, what if the String Control is in a sub-vi, but want to clear it from a different sub-vi?
(3,616 Views)
OK I figured that one out too. I first have to write a global to the local for the control, then write the local to the global, then re-write the global as empty (or whatever) in the different sub-vi when I want it to change.
thanks again for all your help.
(3,616 Views)
