Changing fpga target
Hello LabVIEW FPGA folk,
I have a project on FPGA target X, and I ran out of resources.
I want to recompile it on Target Y to check if I'll be better off.
I've seen this article
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x2H2CAI&l=en-US
Which explains the steps needed to port from target to target.
But in my case I have Multiple FIFO's and registers declared ... I really would not want to go though the process of re-declaring them again, not manually this could be error prone.
Please see screenshot for clarification on what I mean.
So are there any tips any of you FPGA gurus can give me to help me out?
Is there a way I could copy out a section of the LV Proj XML or somethig so that I don't have to re-declare everything by hand like a robot?
Maciej
(3,953 Views)
Accepted by topic author Mac671
Sooo Kudos goes to a collegue of mine.
What you can do is select all the items ( FIFO's and Registers ) that you want to copy.
Go to the LV menu Edit->Copy.
and then go to LV menu in the new project, select the place you want to paste at and then Edit->Paste.
(3,941 Views)
