Changing from Arduino to LINX??
Wow, thanks Gabby for your info and help.
I am going to explore this MakerHub forums.
All the best
Andrea
Message 11 of 18
(2,851 Views)
No problem! Good luck!
Gabby
National Instruments Applications Engineer
Message 12 of 18
(2,831 Views)
Hello, Sam.
I'm doing a project whose objective is the operation of a stepper motor, but not against specific tool for stepper motor, as there were before the LINX. How do I work with this type of engine using the LINX?
Thanks.
Message 13 of 18
(2,763 Views)
Or someone who can help me, please.
Message 14 of 18
(2,759 Views)
I have the same problem!
For now my vi is working well maneuvering servos but due to the needs of more power I have to switch to stepper motors!
Couldn't find any good info about.
I would really appreciate if you share your experience with me about using steppers.
All the best
Andrea
Message 15 of 18
(2,736 Views)
Neither of you have provided nearly enough information about your problems - you need to post detailed information about the hardware you are using, the connections you've made, the code you are using etc.
LINX has the ability to implement custom commands, which I linked to earlier in this thread. Your question is really an Arduino question - about how you can interface your stepper motor to an Arduino and write the code to control it which you can then put in a custom LINX command to control it from LabVIEW.
(blog)
Message 16 of 18
(2,713 Views)
Okay, Sam.
I lay on the schedule, especially with LabVIEW.
I saw a stepper motor work with image code attached, but with the new LINX database can not play the same. We're using an Arduino UNO. I wonder if this kind of engine I have to use PWM or some other device like.
Thanks.
Message 17 of 18
(2,699 Views)
Okay, Sam.
Thanks.
Message 18 of 18
(2,698 Views)
