Changing number of plots in a mixed signal graph is not working
Dear all,
I'm using a Mixed Signal Graph with two plot areas.
I would like to change the number of plots dynamically.
I tried to find the property node to set the number of plot displayed but without success (I found into this forum that there is a "legend: number of plots" proprety node but I don't find it)
When I right-click on the plot area on the front view, there is no option to add plots because it is grayed, I cannot change the number of plots shown...
Could you help me please? Best regards.
Sébastien
(2,528 Views)
You can hide plots with the property Plot.visible. If you want 2 plots displayed, you need to use a for loop like this :
The user can also right click on the plot legend and un-check "Visible"
Unfortunately it does not seem possible to choose the size of the legend like for a Chart with the property you mentioned "legend: number of plots".
You could also send to the graph only the data you want to display.
Yddet
(2,498 Views)
Thank you for your answer.
This does not answer to the questions: why there is no possibility to add or plots by a right-click (not only change the visibility of the plots as you suggested) ans shown on my attached file?
It is grayed and we cannot play with this parameter.
Bests
(2,492 Views)
