Changing output of DAQ in real time
I am currently working on generating a sinusoidal waveform, and I'm encountering a couple of issues:
  1. Waveform Output: Although the waveform graph displays the correct waveform, the actual output from the DAQ is producing distorted or incomplete waveforms. This is not aligning with what is shown in the graph.
  2. Real-Time Amplitude Control: I am unable to adjust the amplitude in real time as intended. The changes I make to the amplitude control do not reflect in the DAQ output as expected.
Could you please assist me in resolving these issues?
Thank you!
(691 Views)
Accepted by topic author Danny0806
Hi Danny,
This is your VI after some cleanup:
  1. After you start the DAQmx task you immediately stop it: which behaviour do you expect from your AO signal in this case?
  2. This is because you don't OBEY DATAFLOW!
    When you want to read an updated value from your amplitude control then you should read from the control and not from a loop tunnel! THINK DATAFLOW…
Your VI is missing ALL error handling.
I recommend to have a look at the DAQmxIsTaskDone function when you use the "Finite samples" mode.
(676 Views)
Thanks a lot for the suggestion. It works now!
(625 Views)
