Changing probe options while running can crash LabVIEW 2025 Q3
I just installed LabVIEW 2025 Q3 (64bit) to test the new features.
While playing with the new Debug Window for just 5 minutes, I noticed that changing probe options while the VI is running can cause LabVIEW to crash.
In the following example, I run a VI with "Execution Highlight: Medium" already set, and while it is running, I change the probe from "Generic" to "Toggle Execution Highlighting":
It sometimes require several changes on a probe to provoke the crash.
Did someone also encountered this bug with LabVIEW 2025 Q3?
Raphaël.
(233 Views)
Filed to NI R&D as BUG 3441486
(172 Views)
