Changing resolution of bins in Histogram VI.
Hello Everybody,
I have been trying to plot a histogram for my photon counting experiment. I am using the histogram.vi, it is working perfectly fine. I would like to add one feature to the histogram that I am plotting, which is changing resolution of bins. In the example code that I have attached, I have used random number generator (generates 1 to 100) to check the histogram which has 100 bins each with a resolution of one, suppose I want to use 50 bins each with a resolution of 2 or 25 bins with each bin holding 4 values, how can I do this?
Also, once the program terminates, How can clear the histogram memory, so that a fresh polt will be poltted?
Thanks for any help
Pradeep.
(3,505 Views)
Accepted by topic author pradeepK
Hi pradeep,
you wired a constant "100" to the Histogram function and now you wonder how to change the number of bins? Don't use a constant here! Doh…
You don't wnat to clear the histogram, but you want to clear your data buffer. Just initialize the Feedback node!
(3,496 Views)
thanks GerdW, Insted of using histo.vi I used general histgrom.vi which has the option of binning.
Have a nice day. Smiley Happy
(3,491 Views)
