Changing scan rate during runtime
I have labview 6.1, Windows 2000 and a PCI-MIO-16E board. I am using 12 channels to log data, all at the same rate. However, I would like to be able to change the scan rate during runtime. On first startup of my main vi I use AI Config and then AI Start to kick off the card, and I am currently trying to use AI Clear, then AI Config and a new AI Start with the new scan rate to restart the card. It works, but sometimes takes a second ro two to start refreshing data displayed on the VI. Does anyone know of a better method of doing this? I don't have an external clock running to sync from, I'm just using the on board timers.
Andy
(2,956 Views)
What you are doing should work. How long it takes for the update to become effective depends on how long it takes to end the original acquistion and how many samples of the new one must be taken before updating the display. One or two seconds may not be too far off if the original acquisition is slow or taking lots of points.
One way around this is to always sample at the highest rate and simply discard the unwanted data when slower sampling is adequate. Of course this may not be acceptable if the hardware or software cannot sustain the highest rate continuously.
Lynn
(2,942 Views)
Configure more than one I/O task at start up.
Start only one at a time.
By configuring the tasks (buffers etc.) up front, the "switch time" can be dcreased.
Make sure your groups numbers are unique.
Ben
(2,931 Views)
