Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Changing slider maximum scale programmatically
WPS
Member
12-21-2003
04:59 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Is it possible to change a slider scale maximum programmatically - it appears that this value is not a write value using property nodes?
0
Kudos
Message
1
of 4
(4,576 Views)
Reply
Re: Changing slider maximum scale programmatically
WPS
Member
Author
12-21-2003
05:11 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
An important note - I have the slider set up as a strict type def so I guess this is why I can't change the value...
1
Kudo
Message
2
of 4
(4,576 Views)
Reply
Nirmal_Sharma
Member
12-21-2003
10:24 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
I am including a vi which programmatically changes the minimum, maximum, start values for a slider scale.
If your problem is different than what I have answered, pl. give the feedback.
Best Regards,
Nirmal Sharma
India
Scale_change.vi 19 KB
1
Kudo
Message
3
of 4
(4,576 Views)
Reply
Ben
Knight of NI
12-22-2003
07:12 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
You are correct!
That gives you two options;
1) Right clcik and choose disconnect from typdef,
or
2) Customize control and make it a normal typdef.
Ben
Retired Senior Automation Systems Architect with
Data Science Automation
LabVIEW Champion
Knight of NI
and
Prepper
LinkedIn Profile
YouTube Channel
0
Kudos
Message
4
of 4
(4,576 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
