Changing temperature measurements using USB 9211
I am using a USB-9211 to record 3 temperatures that are all connected to a waterbath that is set at 21C.  The recorded temps vary over time more than a degree or 2 each way with no apparent pattern.  There doesn't seem to be any reason for this. The water bath is calibrated and is accurate to +-.01C.  I tried using an ice bath with the same results. Do you have any idea what could be causing this variation?
(2,842 Views)
Hey MEY,
Have you consulted the user guide and specifications for the 9211 on our website?  Figures 9 through 13 demonstrate the error in degrees celsius for all the different types of thermocouples.  The user guide is available here: http://www.ni.com/pdf/manuals/371566c.pdf
What kind of thermocouple are you using?
Elijah Kerry
NI Director, Software Community
(2,822 Views)
