Changing text color in a table
hi all
i build my table according my values, in a case i must write "data" as a constant but i want this string in a yellow color.
i've tried this way (see picture) but nothing happens.
where is the problem?
thnx
http://www.sd-studio.it - web design agency
(2,812 Views)
You are changing the text color of the string indicator. Try to create a property node of the table instead.
(2,806 Views)
I've attached an example of how you can use the property node of the table indicator to change the color of the element you insert in the array.
I hope it helps.
MarcoL
(2,776 Views)
