Changing the Default Ports for TCP-Based NI-PSP
Hi guys!
Anyone here knows how to change the default Ports of TCP-Based NI PSP??
I found this link: http://zone.ni.com/reference/en-XX/help/371361G-01/lvhowto/createditlogosxt/
but from that link  C:\Documents and Settings\All Users\Application Data\National Instruments\LogosXT and
C:\Program Data\National Instruments\LogosXT i just need to edit the LogosXT.ini, the problem is those
paths are dont exist on my system..
Anyone here already tried changing the LogosXT.ini and successully changed the ports??
by the way my system in Windows 10..
(2,416 Views)
Hi
Which version of LabVIEW are you using?
Did you check this link? is the same one but on LabVIEW 17, it says that you have to create a new text document and name the document LogosXT.ini and place it in the logos XT subfolder.
http://zone.ni.com/reference/en-XX/help/371361P-01/lvhowto/createditlogosxt/
Create the subfolder if it does not exist.
(2,372 Views)
