Changing the Plot Color of a Cluster Property Node
Hi there.
I am trying to draw a XY Graph, in particular trying to plot different colours for a particular cluster of 2 elements, each of which is a 1-D array of type double.
To plot the different colours, I used a Case Statement so that I could assign a colour to the True or False cases of the Case Statement. I would like to know whether the Property Node for Cluster allows a change in the Plot Color of Cluster. I can't seem to find this function in the various Property Node properties.
Thanks for your help.
(3,693 Views)
You should find the Plot Color under Plot.
Regards
Ray.
Regards
Ray Farmer
(3,693 Views)
Thanks for the tip, Ray.
I've used Plot Color to produce different colors for the Waveform Graph. However, as the Waveform Graph is time-based, the colors fluctuate as time progresses (as the value goes above or below the limit). This is good in a sense, but what I would prefer to be displayed on the front panel is a XY Graph (in terms of X and Y coordinates) that displays the regions of Good and Bad values in different colors.
that is, i'll have a particular route mapped out on my front panel. The challenge is to assign different colors to different values of a set parameter. This is the part that currently stumps me.
Would definitely appreciate the help from you guys.
Cheers.
(3,693 Views)
