Changing the range of a digital Input by the choose of a ring
Hello, I hope you can help me.
My problem: I have a cluster where the user can make the settings. I have a digital input and a ring. When the user now choose a value from the ring, the range of the digital input should be changed to another. For example you choose no. 0 (m³/h) and the digital input should have the range from 200-1000. If you choose now no. 1 (m/s) the value change from 0,0 to 20,0 (one digit). How can I realize that?
Thank you for your help 🙂
(2,786 Views)
Hi Sebastian,
you should use the Range property of the numeric control inside the cluster.
To create a property of a specific item in a cluster rigth click on it from the front panel and use Create Property Node.
See example,
Alberto
(2,786 Views)
Thank you Alberto
You really helped me very much. But I have a problem by creating the proprty node. I can't conntect the node to my numeric control. I only can choose controls out of my cluster. How can I choose the controls in the cluster?
Thank you very much
(2,786 Views)
Hi again,
you have to create manually the property node of the numeric control inside the cluster:
- Go on your front panel
- Right click on the numeric control in the cluster
- Select Create-Property Node
In your diagram you will see the property of the numeric control.
Let me know if you need more help,
Alberto
(2,786 Views)
Thank you very much. Now I've found, how to create it. You helped me really a lot.
Greetings from a beginner in LabView
(2,786 Views)
