Changing the scales of intensity graphs
I am trying to produced a power spectrum versus time display using an intensity
graph. I would like to change the x axis (corresponding to frequncy bin)
into that of frequency (hz) and also have the ability to change the x-axis
into a logarithmic plot so it lines up with the main spectral density display.
I have tried to use a technique similiar to the waveform graph by building
a cluster but as i cant find any information on this i am stuck
(2,876 Views)
Hi Paul
You can achieve want you want by using an Attribute Node of the Intensity Graph -
you can access all the X Y and Z Scale parameters there (Xo, delta X, Mapping
Mode, ...)
Paul Davey
Research Assistant
School of Physiotherapy, Curtin University of Technology
Selby Street, Shenton
Park, Western Australia, Australia. 6008
email: P.C.Davey@curtin.edu.au
Tel. +61 8 9266 4657 Fax. +61 8 9266 3699
"Everyone who calls on the name of the Lord will be saved." Romans 10:12
"For all have sinned and fall short of the glory of God, and are justified freely
by his grace through the redemption that came by Christ Jesus." Romans 3:23-4
(2,876 Views)
