Changing the scanning labview program
Hi Everyone,
I have a program in LabVIEW that is used to scan whole range. I want to modify the program to scan one point stop do some calculations after that and then go to next point and do same thing and repeat it until its done. I would like some help or suggestions with it.
I have uploaded the zip files of the scanner. GPscan.vi is the main program.
What I am trying to achieve is put the scanning program at 1,1 in the sample then take measurement lets says multiply a number with random integer and then go back to 2,1 and do same multiplication and repeat this until the end.
(2,922 Views)
Well, you would need to modify your scan.vi to acquire a single point given the coordinates and accumulate the images in a shift register on the main diagram. Who decides what point to measure and when to go back, etc. Can you explain the process "until the end"? Is a "point" a pixel or an image?
(Also, please use reasonable connector panes. You have way too many terminals. Also remember that idnex array is resizable, so you current code could be simplified as follows:
(2,879 Views)
Hi altenbach,
The scanner is run through the DAQ. The point here is pixel. And the DAQ should automatically move scanner to next pixel once the measurement is done.
(2,843 Views)
What's the origin and history of this code?   Something about it looks strangely familiar -- I have a vague recollection of some prior thread based on code from an academic paper related to raster scanning.
My first advice is a quote I've heard in a couple variations: "a problem well-defined is a problem half-solved."   So the first thing is to consider *carefully* what things do and don't need to change.  And why.
For example, do the calculations you perform at certain positions help determine which future positions you visit?  Or is your trip full of discrete positions known ahead of time?
Will you eventually visit all, or nearly all the same coordinates?  Or will you only stop at a small subset?  And if only a small subset, will an Intensity Graph still be an appropriate way to visualize your results?
As you take altenbach's advice (pro tip: you should pretty much *always* take altenbach's advice) to change the Scan subvi to go to a single target position instead of doing the whole scan, you're going to find that you have to rethink a bunch of the counter code.  There's a strong interdependency among the tasks that's based on the present scheme of hardware clocking through an uninterrupted scanning period.  Switching over to single point at a time behavior will make it harder to sync your AO positioning, your AI measurements, and your CTR measurements.
It's probably going to be non-trivial to get that kind of change working really well over a variety of paths through your field of view.  Longer moves between positions will require correspondingly longer times to accomplish physically, but not necessarily in a linear relationship.   Just one of many implications.   All part of why I advise you to consider very carefully what you're trying to do and why.
-Kevin P
(2,828 Views)
