Changing the size of a gauge within the program
Can someone help me understand why this doesn't work. Is there a different property node that will work better?
(2,665 Views)
Could you give more information about what exactly do you need to do in your VI?
Regards
(2,616 Views)
I have a program with configurable gauges. I built this program into an exe and have several running around the lab. I want the user to be able to change the size of the gauge. I have a pop up where the user can specify the number of gages and I want to add the ability to set the size.
With the Property Node I used in the example, the needle of the gauge moves off center when I resize it.
(2,584 Views)
It appears to be an LV bug.  The bug doesn't occur when I write to the size from a FP control.  Can't figure out what are the specific conditions that cause it to be manifest.
(2,573 Views)
