Changing time between data samples causes Labview 6.1 to freeze
When using labview to record temperature values from an RTD, labview freezes when I switch the data time interval from 7 seconds, to 10 min. I don't know why this is. Any ideas?
(2,931 Views)
What hardware are you using?
What are you using to set a time interval? If you just say "wait 10 minutes" it may need the 10 minutes before it wakes up and responds to any new clicks. OTOH if you have a loop with say, a 0.1 second loop time and a "are we there yet?" to trigger the next recording, LV can respond to clicks and repaints in .1 second.
Les
(2,931 Views)
