Changing value of variable from within subVi
In my MainVI, I want to send a variable, say a Boolean, as an input to a SubVI. If the value of this boolean changes within the subVI, I want to reflect the changes instantly in the MainVi.
How can I achieve this? I know, global variable can be an option but I do not want to use it.
Thank you.
-H
(4,004 Views)
You can pass a reference of the control to the subVI.
Then you can use the 'Value' or 'Value (signaling)' (triggering a value change event) properties to get/set the value.
Hope this helps
(4,002 Views)
I prefer to keep subVIs decoupled from the user interface as much as possible. One thing I have done to achieve this is to define a general purpose UI queue that can pass updates data to the UI task so the user interface can be updated. The queue data can be simply the data itself or a cluster which provides so identifier for the data to be updated and the data itself. Using a generalized approach the data would be passed as a variant. Within the subVI it will post the data to the queue. If the queue doesn't exist the subVI will simply ignore the error and nothing will be posted to the queue. In this manner the application can determine if data updates should occur. For instance, we have a general connection object that encapsulates the different connection interfaces into a class. Applications then will support the various interfaces types (USB, serial, TCP, parallel, Bluetooth, etc.). The read and write methods use the generic queue to post data that is being written or read from the interface. This is handy for applications that will want to provide a monitor of communications to the user.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(3,962 Views)
Try using a functional global (FG) instead.  With the FG, you can save the value into a shift register of the FG and get it later on.
Yik
Kudos and Accepted as Solution are welcome!
(3,950 Views)
H P wrote:
Hello, In my MainVI, I want to send a variable...
What's a variable? 😉
(3,945 Views)
Is the sub-vi really that big/slow that it needs to change the variable itself? The common (the most common?) is to send a variable/thread into a sub-vi and then recieve the result as an output. In this case you can get the output and assign it to the indicator (which i assume you want).
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,937 Views)
