Changing web server refresh to less than one second
I hope that post isn't too confusing.  I'm getting a bit confused, myself. 🙂
To try to sum it up.....
If the example.vi works, then my app will work.
If the simple terminal.vi works, then my app will NOT work.
I've also attached a copy of the app I'm using.  I know... it's a bit cluttered, but I haven't yet mastered the structures method, and I thought this way would be easier for the other folks I work with to understand the app if they need to make a change when I'm not here.  They know next to nothing about LV, but can understand schematics well.  Using the layered structures confuses me sometimes, so I'm sure they'd be lost when trying to intrepret them.
Todd Munsell
Test Cell Manager
Wood Group Pratt & Whitney Industrial Turbine Services, LLC
Plattsburgh, NY
Message 11 of 12
(380 Views)
Well, I finally managed to modify Daytronic's sub-VIs to work with LV 8.5
I had to change a switchable setting to a fixed false boolean value, because for some reason, LV kept switching it back to the default true value.  It took a while to change all the sub-VIs, but now it all works with the add-on comm cards.  Now I just have to change the other apps I made.
I wish I could figure out the "multi-channel read" VIs.  I'm not sure how to configure them, so I have to use individual sub-VIs for each channel of data.  At least I'm finally making progress after several months of fiddling with this problem....  Thanks again for the help.
Todd Munsell
Test Cell Manager
Plattsburgh, NY
Message 12 of 12
(350 Views)
