Channel Name after passing express vi
I'm sending my dynamic data through the express vi (statistic calculation) to get the RMS value.
After the calculation I get my RMS value for each channel but the channel names are missing.
Is there a possibility to keep the names?
pho_nox
(3,112 Views)
Hi pho_nox
here are a programatic solution.
(3,075 Views)
I also tried this but the get/set of the attributes only works for one channel.
--> I wrote a VI with a for loop and an array for getting and setting the names. It works (see attached picture).
But when I insert the vi in my main program I get an memory leak problem after some iterations. Maybe I have to allocate or delete the array in another way?
(3,059 Views)
i think your code is a bit messy
Something easier like that should work without any memory issue :
Giuliano Franchetto
Student at the l'Ecole Nationale Supérieure des Mines de Saint-Etienne, cycle ISMIN (FRANCE)
(3,047 Views)
I try to explain:
I'm reading the size of my dynamic data to get the numbers of channels.
I'm initializing an string array with this size.
I'm writing a channel name in each array index.
Then I'm reading the channel names to set the attrributes for the second signal.
I'm open for any other solution - this was my first try and it works... except the memory leak 🙂
(3,040 Views)
thx I will try!
(3,039 Views)
