Channel OFF/ON program
That makes no sense. I said to use a numeric with the representation set to U8 and the byte array to string function. Since you want to send a single byte, after doing the OR, just typecast it to a string.
Message 11 of 22
(2,058 Views)
Sorry, I still don't understand how to represent boolean value ( value from ON/OFF button) in numeric, and then convert this value to string...
Message 12 of 22
(2,051 Views)
If you want to use a Boolean array, then use Boolean Array to Number.
Message 13 of 22
(2,039 Views)
Yeah, I had in my mind something like that. Thanks! It works.
Message 14 of 22
(2,033 Views)
I am embarassed, sory, it's me again. With my microcontroller's program is everything alright, i checked it by terminals programs. With conversion to decimal integer string array is also everything okay. But when I want to write this to uC, and send it back, i get only weird characters or empty buffer. Can you help me again?
Message 15 of 22
(2,023 Views)
Define weird characters. Right click on the string indicator and select hex display. Does it make sense now?
Message 16 of 22
(2,018 Views)
It doesn't make sense, because nothing is displayed now. I really don't have any idea how to fix it especially when my microcontroller sends and receives data properly in different programs like realterminal.
Message 17 of 22
(2,014 Views)
How does "weird characters" become "nothing" when the string is in hex display?
Message 18 of 22
(2,004 Views)
It's become nothing, but after reset for hex-> blinking value 30 for all combinations. Indicator to normal -> blinking value 1.
Message 19 of 22
(2,000 Views)
I think that values are not properly written to VISA write
Message 20 of 22
(1,992 Views)
