Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Channel Separation - DAQ Assistant
J-hov
Member
12-18-2006
03:52 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I hope this is easy: I need to have seperate indicators showing the value for each channel on a thermocouple module containing ~25 thermocouples. Currently I am using DAQ Assistant and I cannot figure out how to seperate the signals.
0
Kudos
Message
1
of 2
(2,399 Views)
Reply
Re: Channel Separation - DAQ Assistant
mfitzsimons
Active Participant
12-18-2006
05:15 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Use Select Signal to break out individual signals or convert it to an arry using From DDT VIs.
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
0
Kudos
Message
2
of 2
(2,389 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
