Channel names don't seem to work for buffered AI data acquisition
For some reason, I can't seem to get channel names (from MAX) to work correctly when doing a buffered AI data acquisition.    I'm sure the channels are named right because I can do a single AI scan and the data is reported correctly for one channel.
In the buffered AI data acquistion, the problem occurs when I wire the array of strings to the AI CONFIG function.   If I don't use channel names and just manually enter the channels in the array of strings function and set the Device to 2 in the AI CONFIG,  everything works fine.   See the attached VI for what I have that is working now.  However, if I change the text in the array of strings function (the only thing outside of the sequence structure in my VI) to channel names in MAX and take out the Device 2 setting in AI CONFIG, the VI reports all channels as having a value of zero.  Its like they're not being read or something and the default is zero.
Any ideas?    Thanks
(2,504 Views)
Hello TRCErin,
Have you tried using the Tradtional DAQ Channel Constant/Control to input your channel list instead of an array of strings?  It will actually let you browse your existing channels and select them from a list.  Most of the Traditional DAQ examples in the NI example finder use this constant/control to input the channel list if you would like to look at an example.
Eric
DE For Life!
(2,490 Views)
