Characters do not map properly when entered in a string control
In LabVIEW 7.1, running on a Sun Blade 150, characters do not map properly when entered in a string control. For example, the spacebar does nothing and the 'u' key is effectively the left arrow key. This problem does not manifest itself on an identical LabVIEW 7.1 install running on a Sun Ultra 2 with the same OS (Solaris 5.8_29). What is wrong here?
(2,479 Views)
Please make sure that you are using the same font on both machines. The other thing to check would be that you are using a similar keyboard on both Ultra and Blade machines.
Ankita
(2,448 Views)
