Charakters like ř or č are not displayed on dialog box and on front panel
Please can somebody help with displaing sign like č and ř on dialog box or front panel. I wrote text to string constant (dialog box) or directly on front panel as like label. I tryed to use some tools from Unicode library but it doesn´t work.
Thanks you for help.
(1,213 Views)
In labview.ini, if you have
UseUnicode="True"
you should be able to just paste the characters in.
(1,151 Views)
I push UseUnicode="True" to file labview.ini and still nothing. 
(1,132 Views)
Try this.
Note that the "Interpret As Unicode" is like Font and Color properties in that it is changeable from character to character.  When setting it, it affects whatever characters are currently selected.
(1,087 Views)
This characters will most likely display correctly in LV 2024 Q1 or prior to LV 2022.
Bojan
(1,063 Views)
Accepted by topic author Misha4200
I found solution. So first of all I have to export VI String from front panel. So I was click on tools->Advance->Export Strings... . After that Labview generate text file of front panel strings (labels, captions). In this text file I rewrite unrecognized signs and save and close this txt file. After that I import this text file back in to Labview (click on Tools->Advance->Import String...).
PS.: If you want edit label of controls and indicators you should edit caption not labels.
(1,024 Views)
