Chart/Graph for time-stamped data
As far as I understand, dt is a constant along the time. In my application, dt between Xi and Xi+1 varies along the time. Can I use build waveform?
Message 13 of 15
(1,168 Views)
> build waveform?
Yes. In a waveform, the timestamp is the time of the first point in the
array of amplitudes. The dt value is used to compute the time of
subsequent points as time[n]= T0 + dt*(n-1). If you have single point
waveforms, the dT doesn't matter, only T0.
Greg McKaskle
Message 14 of 15
(1,168 Views)
Thank you. Now I understand that the realtime data of variable dt can be displayed in X-Y Graph only and if adapting scroll to it, we shall caught by its too dizzy appearnce.
Am I correct?
Message 15 of 15
(1,168 Views)
if you want to draw the chart with different delta X values you can use X-Y graph. In this case you just have to add new point to this graph at every iteration of your reading loop. You have to use shift registers to pass your grath from one iteration to another.
The example is attached.
Good luck.
Oleg Chutko.
Message 3 of 15
(1,784 Views)
Yes, your VI can display waveform correctly. But I need 10Hz base sampling rate and scroll function. I modified your VI to meet them. It is too dizzy to watch in, writing and erasing x-y graph every iteration.
Message 5 of 15
(1,784 Views)
