Chart History Length in Loop
There are two things, that I don't understand about the solution yet and which I would like to learn for the future:
1. Does it make a difference, whether the graph is inside or outside the loop for on-demand sample acquisition?
2. When I connected the graph directly to the DAQ assistant, there was an error message about incompatible data types. If I first connect the DAQ assistant to a field for numeric output and in parallel to the graph, everything works, suggesting some casting going on. Is this indeed the case? How would I realize as a beginner when it is happening?
Message 21 of 25
(848 Views)
For 2.  Any time there is a DDT (Ugly blue wire) there is likely to be a data type mismatch.  They hide too much code behind them.
Message 22 of 25
(846 Views)
Ah, that is interesting. For me as a beginner the solid blue lines looked quite nice so far.
Message 23 of 25
(844 Views)
Are you using a Graph or a Chart?  A graph will only display the last waveform you wrote to it.  A Chart has a history associated with it.  Generally, charts are best inside of your FOR loop while graphs are best to build up all of your data (autoindexing tunnels, etc) and then write to it when you want to show all of the data.
As already stated, the Dynamic Data Type is an abomination as it hides too many important details (ie what the data actually is).  A graph or chart should accept the DDT coming from the DAQ Assistant I last saw you post.  So I would suspect something changed there.
Message 24 of 25
(841 Views)
  • A chart is an indicator and has nothing to do with sample acquisition. Please define ambiguous terms such as "on-demand sample acquisition". Who is demanding what and how? Show us code!
  • An indicator only updates once it receives data. If it is after the loop, it will not update until the loop has completed. If it is inside the loop, it will update with each iteration. Dataflow!
Message 25 of 25
(833 Views)
