Chart Problem
Dear Fellows,
I have the following problem:
I have a chart with Y-axis the amplitude , and X-axis the time. I am plotting amplitudes for 2 million seconds ! The problem here is: when plotting is over, eventhough I have a scroll back tab , I can only scroll the last few thousand values , but I want to be able to scroll all over the graph ( 0 to 2.000.000) and reach the beginning value time= 0 !
Any Idea ? or Solution?
p.s: When I set autoscale of X-axis from properties of the chart , It tries to put all the values within the graph which I don`t want .
I want it to show the last few hundred values of X-axis  , the rest I want to be able to scroll up to beginning time (0)
Thanks Alot !
Regards
silver
Message 1 of 9
(5,408 Views)
Hi silver,
most probably the history for the chart is set to 2000 values!
Two options:
1) Increase the history length (right-click on chart!)
2) make your own buffer and show only parts of the big array. It doesn't make (a lot of) sense to plot 2 million pixels in chart only ~400 pixels wide...
some cross-linking to this one...
Message Edited by GerdW on 11-27-2007 10:57 AM
Message 2 of 9
(5,403 Views)
Hi Silver,
You need to set the history length to a number big enough to remember all the samples. Rightclick on chart >> Chart History Length. Then you can set a number up to 2,147,483,647.
If you now deselect autoscale and choose an appropriate scale you can scroll as you wish.
Hope it helps you
Pelle S
Account Manager
National Instruments Sweden
Message 3 of 9
(5,398 Views)
thnx for the solution suggestions.It worked that way.
My last question is:
in the chart I see after running the test, I have the " graph palette " for zooming to specific parts. But after I use graph palette , I cant return the original picture again. So now I want to put a button on the GUI  and when you press it you see the original image again.
any idea ?
Best Regards
silver
Message 4 of 9
(5,362 Views)
Hi again,
You can set the scale programmatically by the property nodes max and minimum. I attach an example.
Pelle S
Account Manager
Message 5 of 9
(5,353 Views)
Hi silver,
you can also do a "one time autoscale" using the propety nodes to get the full view back!
Message 6 of 9
(5,350 Views)
would you please convert your code to LV 7.1 ?
thnx
Message 7 of 9
(5,316 Views)
I use LV 7.1
Message Edited by blue silver on 11-29-2007 12:39 AM
Message 8 of 9
(5,310 Views)
Here you go.
Pelle S
Account Manager
Message 9 of 9
(5,304 Views)
