Chart history save/load
I've been occuring a problem with charts for several days.
I have to show the same chart on several VIs. Therefor, I use the "History" property that's supposed to save the history, but it does that in a strange way. It looks like the history saves the different values of my chart, but not the timing (ie : it looks like the history only considers the changes).
Some screenshots maybe more verbose.
(4,062 Views)
Forgive me, I got fooled by the upload tool...
So, 1.jpg is a screenshot a the first VI on which is shown my chart.
I have a button to access the other VI which first save my chart's history to a table, but as you can see on 2.jpg, the chart on the other VI is not similar to the first.
Any idea ?
Sorry for my poor english (and my double post),
Philippe.
(4,057 Views)
A chart's X axis is built by taking an offset (a base time) and a multiplier (Delta t). If the multiplier is different, the chart will look different.
Check the multiplier property in X Scale>Offset and multiplier for both charts. If they're different, change one of them.
___________________
Try to take over the world!
(4,037 Views)
Hello rophle.
As Tst says, you will need more info than just values to recover the original chart. You should download the property saver toolkit (by Konstantin Shifershteyn) from this link: http://www.kshif.com/lv/ . It can be of help to learn how to save/load data and other control properties.
Hope it helps
Cheers
Alipio
"Qod natura non dat, Salmantica non praestat"
(4,031 Views)
My two charts do have the same properties, including the same X Scale multiplier (which is 1).
alipio : I have looked at Property Saver, but I didn't help me out : as my two charts are on two different VIs, I need a global array of "[pstype] Control's Properties descriptor.ctl" type to save my chart properties and to load them in my other chart.
I didn't manage to create an array of "[pstype] Control's Properties descriptor.ctl" type.
Anyhow, thanks for your answers.
Philippe.
(4,015 Views)
Try to recreate the problem with as little code as possible (preferably only one VI) and post it. It will be easier to help you.
___________________
(4,012 Views)
