Chart indicator using dotted line is corrupt in Anti-Aliased mode
If I select sweep mode and dotted line with the 2nd width value (the one after the hairline), than the chart right to the sweep line is shifted. It is strange but I would accept, it as a feature...
But as I switch on Anti-Aliasing, the shifted line gets frozen at some parts while still shifted at other parts.
I tried to reconstruct the same effect in a new VI, but with no success. I attached the original VI, I hope you will be able to see the effect. I also attached a video about the effect.
(2,418 Views)
Hi Komorbela!
That is just the way the graph gets represented by shifting the old graph's dotted line.
But that does not mean that the values you are getting are wrong. It´s just visualization.
Regards!
Martin
(2,384 Views)
