 Ralph@NES
			Ralph@NES
			01-03-2010 11:39 AM
Hello all.
I'm using charts to record data coming from vibration sensors on a bearing testing rig.
The problem I have (or rather the users have) is that the chart seems to only show a minute or so 'window' of data and it moves along through the day that way. Adding a scrollbar on the axis helps, but doesn't give a real 'picture' of a specified time range.
We'd like to have the time range of the chart be about 12 hours. Is there a simple way in properties that you can set the chart to show 'last X amount of time'? Or at least something greater than a minute!
Thanks for bearing with me. There seemed to be several posts sorta similar to this, but none really addressing the exact issue.
 Dennis_Knutson
			Dennis_Knutson
			01-03-2010 12:15 PM
 stevem181
			stevem181
			01-03-2010 06:49 PM
Hi Ralph,
> I'm really, really confused.
Don't feel alone, this was not obvious to me either.
Here is an example in LV 8.5
You can set the log interval and the number of hours to be displayed.
steve
