Chebychev Polynomial fitting results show multi lines
I am using "nonliear curve fit.vi" with defined Chebychev Polynomial  function to fit XY data.  Strangely, if I enlarge the upturn part, I clearly see the fitting results show multi-lines (2-4) . Please the the attached snapshot.
weitong
LV2013
(2,720 Views)
Can you please attach the actual VI?
(2,715 Views)
Thanks.
 I found the reason: the data X values are not mononicaly, i. e.  there are local oscillations at some region.
After sorting the raw data, the fitting results show single line.
Is the sorting of X values necessary before Chebychev Polynomial fitting?
(2,688 Views)
