Check Array have only Identical Elements
Try to write a program in LabVIEW ,that check if an array have only Identical values in its indexes ,but couldnt find any good solution.
Please do suggest how to do this.
Attached the String array constant contain array of undentical elements and Identical elements.
Message 1 of 13
(11,173 Views)
use compare function
With Regards
Miraz
Kudos is better option to thank somebody on this forum
Message 2 of 13
(11,142 Views)
Hi Miraz,
To be clear from my side,If an array have 5 elements and all the 5 elements should be identical to themselves this is what i need to check.
My picture might be confused you.
Please do suggest on this.
Message 3 of 13
(11,125 Views)
Accepted by topic author Dskp
Hello Selvan,
I think you are looking for this kind of solution, please see below image.
Kudos are always Welcome.... 🙂
Vinal Gandhi, CLA
Message 4 of 13
(11,113 Views)
HI Vinal,
Great !!!Smiley Happy
Expected the same.
Selvan
Message 5 of 13
(11,054 Views)
You can minimize the number of possible iteration by a factor of n (the array size) if you use the Rotate 1D Array function.
Ben64
Message 6 of 13
(11,028 Views)
Hi Ben.
This too working fine.
Thanks for your work.
Selvan
Message 7 of 13
(10,994 Views)
Your example does not show arrays with only identical elements. Your left array has one or more duplicate elements. Is that what you are looking for? It seems you want to check if all elelents are unique or not, right?
Message 8 of 13
(10,976 Views)
you are right.
to be simple,need check if an array have  unique values.
Please dont confuse with the image,it just for an example something for reference.
Selvan
Message 9 of 13
(10,952 Views)
Check if all elements are equal:
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 10 of 13
(10,872 Views)
