11-21-2005 05:44 AM
Rebecca,
>> 2. I know I can detect a NI VISA driver to read the device. However, if it's a USB pen drive, the windows will automatically load the Windows driver for the USB, the PC will bypass the NI driver. So, I can't use the NI Visa driver wizard.
There is a way to assign NI-VISA RAW driver to your Pen device, instead of assigning the Windows default driver. First create an INF file that explicitly contains your VID/PID. You can machine-generate the INF by using NI-VISA USB driver wizard tool. Once the INF is generated, place it in the Windows/INF direcoty. Next open the Control -> System -> Device Manager tab, then go for your USB device node then "Update" the hosting device driver replacing with the generated INF file, which makes NI-VISA RAW driver host your Pen device instead of the Windows default driver.
This approach allows you to override any class driver that host a class device, swapping to an arbitrary device driver to host, as long as a correct INF file (containing explict VID/PID entry in it) is placed in Windows/INF directory.
11-21-2005 05:48 AM
I tried to access the thread but it said the Message has been deleted. Could you please advise again? Thanks
11-21-2005 05:56 AM
11-21-2005 06:50 AM
Hi all,
i got my problem solved using the Devcon.exe method. it's very useful, just like the Device Manager. Thanks a lot for the quick help! Thanks!
01-21-2010 02:17 AM
Rebecca,
would you send me the VI that read the PID and VID of the USB Drive without using the NI VISA development wizard?Labview will be automatic detect the windows inf file and install the driver.
