Check String Control for Content
Hello! I am using Labview to communicate via GPIB. I would like to send a certain command only if a specific string control is empty. I was wondering if there is any basic or straightforward way to check if a front panel string control is either empty or if it has content? Thanks in advance!
(3,781 Views)
Accepted by topic author jfherrm
"Empty string?" under comparison pallette.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,774 Views)
Use a case strucure and wire the string to the selector. See example.
(3,768 Views)
What would you like to do if the string is empty?
(3,744 Views)
