Check array if there is a duplicate value
I know that this should be simple, but I am not converging to a simple solution.
I would like to just generate a TRUE value if there is a duplicate value in an array.
This is what I have thus far (but doesn't work):
Can you offer some guidance as to a simple elegant solution to return TRUE if there is a duplicate?
Thanks for your help and time!
Message 1 of 14
(6,286 Views)
The following code should work. This is going to run O(n^2) so It'll get really slow for larger arrays, but I'm not sure you can do much better with unordered arrays.
Message 2 of 14
(6,268 Views)
Accepted by topic author hiNI
Message 3 of 14
(6,246 Views)
Didn't even know there were sets in LabVIEW, so thanks! This is a better solutions than mine for sure.
Message 4 of 14
(6,241 Views)
It was added in 2020 or something.
Qestit Systems
Certified-LabVIEW-Developer
Message 5 of 14
(6,184 Views)
This code makes absolutely no sense!
  • It does not return anything! (There is no indicator)
  • You search the entire array for an element that is guaranteed to exist, so the search output can never be <0.
Yes, Maps and Sets were introduce in LabVIEW 2019, have a look at my presentation for details. They offer a good solution.
Even without the use of a set, this will probably OK for typical scenarios:
Message 6 of 14
(6,142 Views)
Without sets this is possibly a better solution with a runtime of O(n*log(n)), though it might lead to the array being copied.
Message 7 of 14
(6,088 Views)
Yes, sorting first can be an advantage for very large arrays and very few duplicates, but why would you need two instances of index array and that +1??? It is sufficient to resize to two outputs and wire [i] to the top index and the second one will automatically be [i]+1.
You can also delete the first element, autoindex over the rest, and compare current to previous. Here are two possibilities: Version B is your example, but cleaned up a bit. 😄
Message 8 of 14
(6,066 Views)
Be aware that anything that relies on an equal comparison will not be able to tell if there are duplicate NaNs in the array.
If that is a concern, the "set" or my earlier version will still work correctly!
Message 9 of 14
(6,049 Views)
Could be a relevant edge case, though checking floating point numbers for equality is code smell and usually a bad idea IMO. I assumed that we're just using floating point in these examples because it's the default.
Message 10 of 14
(6,033 Views)
