Check for Items Source Control Status in Project Explorer
Is there a way to check what items in the Project Explorer are not currently under source code control? Perhaps through property nodes? I didn't see anything that looked like it could be done this way, but I would like to know if there are items in my project that are not in source control that should be in source control.
(3,295 Views)
No ideas about this?
(3,282 Views)
Hi zenthoef,
I do not believe there is any way to tell which files are not currently under source code control through LabVIEW. My only thought is that you could make a call into the source code control API. However most likely the API is not open to external calls and it would depend on what source code control you are using.
<Brian A | Applications Engineering | National Instruments>
(3,274 Views)
integrated source code control is one of the advantages of LabVIEW Pro and using projects.  Properly configured the project explorer DOES indicate in SCC, not, in SCC, Checked out by you from SCC and Checked out by other from SCC.
(3,269 Views)
