Check if File or Folder exists Issue
I have observed a strange issue with "Check if File or Folder exists". It says file exists even if the string is empty.
AB
Kudos are Accepted
(6,854 Views)
Actually Empty path refers to the mapped drives in the computer. You can check the detailed help for the same.
For the same you should use "<Not a Path>" instead of empty if you are not intended to input a path.
(6,836 Views)
Use Empty path check before checking for Path exists
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(6,827 Views)
Accepted by topic author AB@17
(6,825 Views)
The VI itself has the check internally
AB
Kudos are Accepted
(6,814 Views)
