Check if User Event destroyed?
Is there some way of checking if a User Event has been destroyed, or is even active before registering?
For instance, if an event structure has registered to a User Event - then the User Event gets destroyed run time, is there some way to recover/get an error in the event structure that the User Event it's waiting for no longer exists?
Cheers
(3,883 Views)
Accepted by topic author rthomas101
Use the built-in function on the Comparison palette "Not A Number/Path/Refnum?"
(3,862 Views)
Perfect! Thank you, it's been driving me nuts for days.
(3,855 Views)
