Check if file is older than a time period
I want to check if a file is older than a time period like 1 or 2 days then perform an action on this result?
I have not lost my mind, it's backed up on a disk somewhere
(2,988 Views)
Accepted by topic author PauldePaor
Hey,
Quick and dirty see attached file.
CMW
(2,979 Views)
Yup this is how you do it.  The only change I would make is if you are going to have a constant on your block diagram of 2 days, right click the constant, go to properties, the Display Format tab, then choose Relative time.  This changes the look of the control but not the value.  This way 2 days can be represented with 48 hours which is a little easier to understand then 172800 seconds.  You can do this on controls too by the way.
(2,959 Views)
Oh and keep in mind that this is if the file has been modified in the last 2 days.  If you want to know the file creation date, or the last date that the file was accessed you'll need some other Windows DLL calls.  I believe there is also a OpenG function under File I/O that does this.
(2,957 Views)
