Check multiple files in and out of SCC
I'm using the built in source code control that comes with Labview 6.1. Is there a way to check in and multiple files. What I'd like to do is to mass check out my entire heirarchy (100's of files!) modify a global variable that effects almost everything, then mass check it back in. Can i do that?
(2,589 Views)
You CAN do it, but you need to select each file you want to check out (by holding down the key and selecting multiple files). It might be easier to do using a 3rd party source code control such as Perforce. But here is a link to a knowledgebase that talks about this exact issue:
http://digital.ni.com/public.nsf/websearch/4D03AD2C283D596386256ACD0076E89F?OpenDocument
(2,589 Views)
