Checking for GPIB devices
   I have some code that sends a "*IDN?" to GPIB addresses 1 thru 31, if I get a response to the query I assume that a GPIB device exists at the address. This approach gets all hosed up when I have a GPIB instrument that does does support/recognize the *IDN? query.   MAX however is able to recognize that a GPIB device does exist at the address of the instrument that I have. Any ideas of how to recognize/detect if a GPIB device exists if it does not respond to a *IDN?
Regards
Kaspar
Kaspar
Message 1 of 9
(7,696 Views)
I don't remember the exact sequence that is used in MAX. It uses low level GPIB functions. To get the sequence of function calls, turn on NI-Spy and do a Scan For Instruments.
Message 2 of 9
(7,687 Views)
  I used NI-spy to see what Max does and looked at the low level calls. There is a function called FindLstn that finds all of the listening devices on the GPIB bus. So now I have to see if there is such a low level call in Labview. The saga continues...
Kaspar
Kaspar
Message 3 of 9
(7,661 Views)
Message 4 of 9
(7,652 Views)
Accepted by topic author Kaspar
Use the function of the same name on the Instrument I/O>GPIB>488.2 palette.
Message 5 of 9
(7,651 Views)
  I used the find listener function and it works just the way I want it to. Now I have a way to identify devices that do not respond to a *IDN? query.
Thanks again....
Kaspar
Kaspar
Message 6 of 9
(7,632 Views)
Hai Kaspar,
Can you please post that code. This will help me now and will help others also in future.
Mathan
Message 7 of 9
(7,237 Views)
When I press the Start button of NI Spy, nothing happens. It stays only blank. Smiley Indifferent
Am I using it wrongly?
- Partha ( CLD until Oct 2027 🙂 )
Message 8 of 9
(7,191 Views)
It stays blank initially. Once you start sending some commands, it will be captured. Launch NI Spy and use MAX - VISAIC (VISA Interactive Control) and do some change in attributes and see what's happening in Spy.
Mathan
Message 9 of 9
(7,171 Views)
